i need old bike parts!!! 84 honda xl125
Posted by: bluerider125---------------------
ok this is not my bike but it is my friends. it needs a lot of work, and some new parts. heres the list:
1) seat--> it is a board wrapped with a blanket
2) gas tank--> has rust on the INSIDE of the tank, instant carb/engine killer. also dented severely.
3) clutch cable--> missing. also clutch lever
4) brake cable--> missing, also brake lever(front)
i know, sounds bad, but it is really worse than it soundsgot it for free though!
please help me out.
-Rob
Posted by: OnAnySunday---------------------
Well you have several options:
I know this sounds a bit silly, but check -w- your friendly nieborhood Honda dealer. I bet most (if not all) of this stuff is still available.
My bikes an '82 and i can still get these items for it.......knock wood.
There are tons of parts on their for us old Honda fans!
Check -w- Clarke manufacturing for the gas tank, if you dont want a stock steel unit. They may have something to fit.
If not you can always pop out the dent "kreem" it, and repaint.
The cables and levers should be plentifull through the aftermarket.
(again, check -w- your dealer.)
And be forwarned........ once your buddy get that 6 speeder running good, you may need to do a few mods to that TTR to keep up...... :D
Good luck!
