KTM/Suzuki seal swap
Posted by: zilla---------------------
I have a 98 380 EXC. Seems the forks leak constantly.. I am going to rebuild them soon, new bushings/seals etc.. A friend of mine recently told me of a thread he read here where someone replaced the KTM seals with Suzuki seals. It required a small part of the fork to be machined/removed.. Anyone have the details, part #'s or inside scoop? Thanx
Not sure about machining but you can use the seals/dust seals from a 1996 rm 125.These do cause a little stiction.The later WP seals were better -i think they were blue instead of red but i might be wrong.
Posted by: Wakisashi---------------------
I think the machining is on the newer WP 43mm inverts to use a seal from a KYB 43mm fork. I think it is in an article in one of the current mags.
Posted by: motoeuro---------------------
tighten the seal tension springs and you should have no more problems.
remove 5mm from the new ones before putting them in.
