Ktm 400 Exc Vs. Sxc Diff?
Posted by: bayneman---------------------
Help! Looking to buy used and have ops for both. Differences/preferences/problems of each? Want to dual sport with magic button if possible. Thanks!
Posted by: MrLuckey---------------------
If you are going to dual sport then the EXC would be cheaper and easier for you to convert! I believe the main diffs are:
SX - little or no flywheel weight - quicker revving
EXC - not sure how much but I'm fairly certain it has some weight
SX - close ratio gearing
EXC - wide ratio
SX - no lighting coil
EXC - lighting coil, headlight, taillight.
SX - Slightly smaller gas tank 1.9 gal vs 2.3 or 2.5
EXC also is e-start.
Those are the main things I can think of.
