Wanted KX 250 front end
Posted by: vandean---------------------
Anyone know where I might find a KX 250 front end to fit my 02 220????
Does anybody also know where Sage posted any info about how he installed his???
Ask sage:
http://www.sagesdirtandstreet.com/
'kx...to fit..kdx'? Covered this in another thread. They don't just 'fit'..but you knew that, right?
Check this:
http://dirtrider.net/forums3/showth...?threadid=32587
..for a write up on sages kx/kdx marriage
Fredette makes 'em, too. Well...a 220 in a KX frame. Check on it thru CDave's page:
http://justkdx.dirtrider.net
Cost? 'If you have to ask, you can't afford it'
Posted by: Sage---------------------
press the kdx stem into the kx lower clamp, install the lower clamp, build a 10mm (ring) spacer & slide it over the stem, call Emig and have them bushing a KX top clamp for you, front end install complete, Then you need adjustable pull rods in the rear to balance out the chassis and get your steering angle back. After that I had Jer whip up a KX/KDX valving kit for me so the ends wouldn’t fight about the transplant.
As far as other posters that have ridden it, RobRaz is the only one that posts here that has ridden it.
