YZF Parts For sale
Posted by: Thump---------------------
Front Wheel with disc: $150 Needs to be trued
Part #'s and YOT cost below:
4SS-25111-00-00 **HUB, FRONT 1 $146.36**
93306-90403-00 **BEARING 2 $10.71**
5DH-25117-00-00 **SPACER, BEARING 1 $7.54**
93102-26468-00 **OIL SEAL 2 $4.43**
94416-21613-00 **RIM (1.60-21) 1 $174.99**
4DA-25104-00-00 **SPOKE SET, FRONT 1 $59.00**
94309-21161-00 **BAND, RIM (70-80/100-21) (DUNLOP) 1 $6.46**
2J5-25394-01-00 **SPACER, BEAD 1 $26.29**
5BE-25181-00-00 **AXLE, WHEEL 1 $29.47**
5DH-25183-00-00 **COLLAR, WHEEL 1 $17.48**
5BE-25186-00-00 **COLLAR, WHEEL 1 $21.32**
4XM-2582T-00-00 **DISC, BRAKE 1 $121.50
Stock Exhaust: $50
5BE-14611-00-00 **PIPE, EXHAUST $122.05**
5GR-14753-00-00 **SILENCER, EXHAUST $453.84*
Airbox: $50
5BE-14401-00-00 **AIR CLEANER CASE ASSY 1 $94.50**
5BE-14453-00-00 **JOINT, AIR CLEANER 1 1 $53.94**
3JD-14459-01-00 **HOLDER, GUIDE 1 $21.44**
3JD-14477-00-00 **PLATE 1 $37.54**
5BE-14458-00-00 **GUIDE 1 $10.34**
5BE-1441A-00-00 **COVER, CLEANER CASE 1 1 $22.68**
5BE-1441E-00-00 **COVER, CLEANER CASE 2 1 $22.68**
MX-Tech Forks: $500
5GR-23103-L0-00 **FRONT FORK ASSY (R.H) $623.95
5GR-23102-L0-00 **FRONT FORK ASSY (L.H) $623.95**
MX Tech Rear Shock: $200
5GR-22210-00-00 **SHOCK ABSORBER ASSY, REAR 1 $560.59
Complete front brake assembly $100
5DH-2580T-00-00 **CALIPER ASSY (LEFT) $185.61
4SS-W2587-00-00 **MASTER CYLINDER SUB ASSY $196.44*
4SS-2538E-00-00 **NUT, ADJUSTING 2 $3.63**
4SS-83913-00-00 **COLLAR, LEVER 1 1 $9.86**
3YX-25866-10-00 **CIRCLIP 1 $2.79**
4SS-25866-00-00 **CIRCLIP 1 $1.27**
4SS-2583G-00-00 **WASHER 1 $1.47**
4SS-83922-01-00 **LEVER 2 1 $22.65**
95606-06100-00 **NUT, U 1 $0.76**
4SS-2589F-00-00 **BOLT, LEVER 1 $1.97**
3YK-25867-00-00 **BRACKET, MASTER CYLINDER 1 $4.70**
4SS-25833-00-00 **BOLT, FITTING 2 $0.40**
Complete rear brake assembly: $120
4XM-27200-00-00 **PEDAL, BRAKE $104.70*
5GR-2580W-00-00 **CALIPER ASSY, REAR $209.40
5BE-2583V-00-00 **RR. MASTER CYLINDER ASSY. $91.47
5BE-2117M-00-00 **COVER 2 1 $22.28**
92014-06016-00 **BOLT, BUTTON HEAD 2 $0.60**
95027-06012-00 **BOLT, FLANGE 1 $0.38**
5DH-25873-00-00 **HOSE, BRAKE 2 1 $59.60**
90401-10172-00 **BOLT, UNION 2 $1.61**
90201-10118-00 **WASHER, PLATE 3 $1.28*
Ignition and wiring: $75
5GR-85540-00-00 **C.D.I. UNIT ASSY 1 $207.25**
5BE-85546-00-00 **BAND 1 $9.03**
5BE-82310-00-00 **IGNITION COIL ASSY 1 $67.85***
5BE-82370-00-00 **PLUG CAP ASSY 1 $55.50**
5BE-82540-01-00 **NEUTRAL SWITCH ASSY 1 $35.26**
5BE-82509-00-00 **WIRE, SUB LEAD 1 $32.08**
Kick starter: $20
5BE-15620-02-00 **KICK CRANK ASSY 1 $108.29
Decompression perch/cable: $10
583-83981-00-00 **LEVER, DECOMPRESSION 1 $9.44**
5BE-83913-00-00 **COLLAR, LEVER 1 1 $1.53**
5BE-82912-00-00 **HOLDER, LEVER UPPER 1 1 $15.10**
38V-82913-00-00 **HOLDER, LEVER LOWER 1 1 $7.07
Skid plate impeller guard: $ 15
5BE-21471-00-00 **PROTECTOR, ENGINE 1 $54.88**
5BE-2147A-00-00 **GUARD, ENGINE 1 1 $38.89
Sub frame: $50
5BE-21190-00-P0 **REAR FRAME COMP. (DPBMC) 1 $217.40
Posted by: biglou---------------------
I have to pass on the wheels David. Just can't do it right now. Thanks for keeping me in the loop, though.
Lou.
Posted by: Hot4Teacher---------------------
What year is it? I have a '99 and I am interested in the subframe. If it is a different year will it fit? Thanks.
e-mail jdavis72399@msn.com
It is a 1999.
Posted by: quadridermx---------------------
sent you an email...
quadridermx the wheel is yours for the price you sent me if you still want it.
^^^^ Prices cut. See above ^^^^^
Posted by: JuliusPleaser---------------------
I just dropped the MO for the kill switch in the mail. You should get it in a couple of days.
Thanks again! It looks great on my Z50.
What? I thought you were going to pay me at DW02?
I will. :D
Posted by: IrishEKU---------------------
Thump,
I'll take the clutch lever and perch assy. I have a nasty habit of leaving broken perches all over LBL. PM me with your addy and the check is in the mail.
Phillip
Irish, check your PM
Irish got the clutch perch.
Other prices have been cut again. If you know of anybody with a YZF you might point them this direction.
I'll tell YZ400guy as soon as he gets in from the feild tonight. He may be interested in the skid plate and the exaust.
PK
Prices slashed again. Need the $$
Posted by: CanadianRidr---------------------
I know it's not listed thump but do you have plastic for the bike?
Some plastic.
Send me a PM of what you need.
Prices have been slashed. I must sell the remaining items.
Posted by: TobyS---------------------
I was wondering if you would sell just the font master cylinder and if so how much would it be? Please e-mail me back at foxracing3@aol.com.
Thanks,
Trevor
Posted by: azrick---------------------
do you still have the exhaust including the header pipe. Contact me at rbw71@uswest.net
Posted by: Pat Sorrells---------------------
This is probably way too late, but do you have a tank or any other plastic remaining??
Toby, Azrick.. I sent you both e-mails
Pat, sorry man, too late.
