Originally posted by steve125: how "bout" some hints. http://dirtrider.net/ubb2/confused.gif |
Originally posted by fastkevin: The ti valves are used to allow it to spin up faster. |
Originally posted by BOOMER: first i like to say Rich's comments are true-to some degree. but if the valve diameter is the same as steel valves-you DONT get more valve area. |
Originally posted by BOOMER: the only advantage to a ti setup is reaching peak horsepower by reducing the time to do so & the ability to reduce parasitic losses thru the valvetrain. |
Originally posted by BOOMER: the ti valves are going to allow a engine built to accelerate(dirt bike) to rev higher-but with no real big power gain. |
Originally posted by Dirthead: If doing a comparison between a steel valve and a ti valve using equal spring pressures, the ti one will close more quickly than the steel. |
Originally posted by Dirthead: Consequently if you can then use lower valve seating pressure (i.e. softer valve springs) to accomplish equal peak rpm characteristics, you have effectively decreased friction in the valve train and increased horsepower at the crank. |
Originally posted by MXN4FUN: Rich, are you saying the advantage of titanium valves minute unless coupled with a cam. |
Originally posted by rick#3: is Yamaha working on a new engine for the YZF? |
Originally posted by motopuffs Honda uses 2 titanium valves because they need the room in the head, and smaller springs allow this. |
I am not too familiar with the YZF internals, but I was curious to know if Yamahas valve weight reduction efforts extend to the retainers, keepers, and buckets(lifters)?
Originally posted by MXN4FUN Is it possible that Honda uses titanium intake valves for the purpose of reducing spring pressure? They want to have a longer duration of valve opening coupled with a steep closure angle on the cam lobe. By lessening the force needed to close the valve it limits wear on the seat by not creating as much valve seat pressure. |
Originally posted by Boozer Why are the exhaust valves smaller than the intake valves in almost all 4 valve engines. im new here and was wondering what it is you do, and your educational backround. |
Originally posted by cp380sx Three smaller valves may have the same head area as two larger valves but they will out flow the two larger valves because of a larger area under the valves at full lift. |
Originally posted by cp380sx I think that's more because of dynamics of the airflow and port design. The center valve has to deal with a lot of turbulance. |
Originally posted by cp380sx The 5 valve Ferrari engines have some of the highest VE ratios in the auto industry so I think there is more potential there. |
Originally posted by rick#3 Very interesting Rich thanks. Is their any true to a 5 valve head creating more heat. If I remember correctly I read an article regarding building a superbike with an older Yamaha 5 valve and one of the issues they said was the extremely large radiator required. |
Originally posted by cp380sx The 426 could use some low end. |
Originally posted by cp380sx Obviously the center valve will have the highest flow rates because of it's central location but it's cylinder filling capabilities will be compromised because of it's adjacency to the other intake valves and their charges. |
Originally posted by Humai Compared to what? I suggest if you compare the YZ4xx to any other four-stroke under 520cc you will be hard pressed to find another engine with markedly superior torque characteristics at operating revs, including "low end". |
Originally posted by cp380sx Variable valve timing is the key to having your cake and eating it too. |
