How is the XR400 for dual-sport use?
Posted by: Mark Parsons---------------------
I'm considering buying an Xr400 to convert to dual-sport use and wonder about its street manners. The bike will be used mainly for commuting and some longer range stuff. Since it only has a 5-speed transmission I thought it might get a little "buzzy" on the highway. I plan to go up 1 tooth on the countershaft sprocket and maybe down some teeth on the rear sprocket. Any opinions?
Posted by: sizzler---------------------
I own a XR400 that I have converted to a dual-sport with a Baja Designs kit. The only reason for this is that I wanted to access close-by trails straight from my garage. Used this way the bike works perfectly fine. However, I don't think I would ever take the bike on any kind of freeway (I ride primarily trails/woods/dirt and I don't have DOT tires on my bike anyway). If the bike is primarily for commuting and only occasionally off-road you should look at an actual production dual-sport machine (such as the DRZ400 dual-sport). You'll find that it'll be more "road friendly." Just my $0.02!
Posted by: TexKDX---------------------
Mark -
If it were the only bike you owned and you were tight on money, then the XR400 would work OK as described. An XR650L would work better is your commute is more in town, and a KLR650 would be preferred if the commute had more highway or fast two lane in it.
Keep in mind my offroad-oriented DS bike is a street legal XR280; my road-oriented DS bike is a KLR650; my street bike with some groomed gravel road riding is a BMW R100GS. I've had a converted WR400, ridden the 650L back-to-back with the KLR and XR, and have ridden the XR400 and DRZ-E and DRZ-S
The DRZ-S is a good bike if money is not an issue and you can tolerate a small hard seat. The 650L gives you SIMILAR offroad capability to the DRZ in that it is the most dirt-oriented of the big bore DS bikes, but has a superior seat. The 650L is also available for much less used if money is a consideration.
When it comes to real road use of an XR, a friend of mine did a similar thing to what you describe to doing to a 400 - he sold his BMW just before a planned long vacation of riding. So, he took his XR 600 and did the following:
Big tank, low front fender, Avon Gripsters, geared it way up, Acerbis handguards with fairings, added one inch of foam to the seat, rubber footpegs, adapted dog packs as under seat saddle bags, and fashioned a tupperware lid as a fairing to the headlight assembly. He cranked out 3650 miles in 2 weeks on the bike on a ride from Colorado Springs up and around Montana and back.
How's that for versatility?
