91 Cr250 rear shock leaking??
Posted by: offroader---------------------
Got home last night and noticed a thin oil leaking as I pushed the bike into the garage. It was dripping from off of the shock linkage. Is there a seal on the shock that can wear?? If so is this the common effect of that?? Truthfully, I didn't even know there was oil in the shock, but I guess there has to be as it's a moving part creating friction.?.? How hard is it to replace the seal?? Or.......how much does it cost to get it replaced if I take the shock out myself and take it somewhere?? Thanks a lot!!
[This message has been edited by offroader (edited 03-19-2001).]
Nobody knows??
Posted by: minutz---------------------
yes there is a seal in there that wears out, along with a bushing that the shaft rides on, hopefully the shaft is o.k. expense will be in the 100 to 150 range with a rebuild and seal head. its 10 years old, it due!
try mx-tech, he has stuff for the older bikes i'm sure.
Are you saying 100-150 for parts and labor or just parts?? How hard is it to replace?? Thanks
http://www.100megspopup.com/tachnem
Posted by: scott_ktm---------------------
I do not think you want to mess with it yourself. You need special tools and must be charged with nitrogen, etc. Hopefully it is just a seal. I have had the shaft on an old KX wear down to the point it had to be rechromed. $$$.
“ If we weren’t all crazy we would go insane” Jimmy Buffett
'99 KTM 380sx
