over reving right turn only
Posted by: speedyts49---------------------
My bike rpms go up when I turn the front wheel to the right. This is at idle. I tried to adjust the cable at the trottle but it did not do any good. I recently had the needle out to see which I had and I don't think it happened before that. It seems to run fine other than that.
'93 KDX200 <- this one
'77 MR175
'78 PE175
Posted by: 01HondaCR---------------------
I think you had the right idea in the first place. I think your throttle cable is messed up somewhere along the line.
Posted by: kevinkdx---------------------
I believe you throttle cable is incorrectly placed so check the routing and make sure it is corret.
Posted by: BRush---------------------
What he said.
Posted by: Speedy---------------------
Hey i am the only "Speedy" hehe J/k
Posted by: clutchcover---------------------
If I am not mistaken there should be a little amount of free play in the cable. Check this. It may not have enough. It may be pulling when you turn. Check routing like everyone else said too.
Sure enough I had got the cable to the left of the gas tank and it should of been closer to center where there is a gap created for the tank to fit over the frame. It is now unrestricted. Duh.
will the real speedy please stand up.
HeHe!!!!
