Trouble pulling muffler apart for repack
Posted by: Boot---------------------
I'm having trouble getting my oval FMF muffler apart to repack it with fresh fibreglass. Anyone know the secret to this operation?
It looks like it should be simple. I've removed the small bolts that seem to hold the outer canister to the end plates, sprayed it with penetrating gunk, and tried whacking the core / endplates with a rubber mallet while holding the canister. It doesn't budge even a smidgeon.
Am I missing something obvious?
Posted by: fatty_k---------------------
Did you drill out the rivits? It took a little bit of encouragment to get my turbine core II apart as well. What model of FMF silencer is it?
G'day Kyle. I don't know what the model the muffler is. It came with the bike and doesn't have anything on it to identify it. It's an oval shape, about 30cm long, 10cm high, with 3 ribs running along the length of the two flatter sides.
It doesn't have rivets to drill out. Instead it's got three small bolts up the front and two at the back. These do the exact same job that rivets would normally do. I would expect the canister to just slip off, but it won't. Maybe I just need to whollop it even harder?
Posted by: 70 marlin---------------------
try a little heat. I made a nice paper weight out of my son's fmf ISDE silencer. trying the wack it method.
