Using Momentum 2-Day Slim Down to lose weight.
Posted by: Racer_x4---------------------
Has anyone ever used the product "Momentum 2-Day Slim Down to lose weight before? I am thinking about buying a bottle, and supposedly you pre-mix this with 8oz. of cold water and drink at least 8 glasses of water for 2 days and you can lose up to 12 lbs. in a week and use it once a week until you reach your goals. For me I would probably use it twice to reach my goals along with a lot of running and exercise. It costs $39.95 for each bottle. Here is the site if anyone wants to check it out: http://www.slimdown-now.net
Posted by: Lemming---------------------
Sure go on it if you think that dropping 12 lbs of water is important Then after that week go out and do a few motos, an enduro, or harescramble and you will experience first hand the effects of dehydration on performance.
How could you be losing water if all you are drinking for two days is tons of water??
Also I won't be doing any motos or anything until past November anyways...
Posted by: Wakisashi---------------------
It is the stuff you put in the water that makes you loose fluids and dehydrate. Fat loss is not a quick process , it takes time to take it off just like to put it on.
Posted by: agnOstos---------------------
Actually, water is one of the best diuretics there are. If you wanna lose water weight, start drinking a ton of water and if you don't normally drink a lot of water to begin with you will pee every other 10 minutes and you will lose weight, but it will be water weight. Being fully hydrated is very important to have muscle contraction. Without water you cramp, one of the fun side-effects of dehydration. You can become weak, shaky, light-headed, etc. If you mess up your electrolytes you can even become gravely ill.
Posted by: Anssi---------------------
You can loose maybe three pounds per week of fat, and even that is pushing it and you will probably loose some muscle also. About 1.5 lbs is something you can do via diet and exercise and still keep fit.
Posted by: SPD---------------------
Go ahead and waste your money. You might want to invest in some T/P paper, because you'll be visting the toliet alot. Annsi's right 1-2 pounds aweek.
All I wanted was something to help me lose some weight and all, and I don't even like thinking about using these so-called "miracle products" anyways because of the chances of hurting your body, but it was like one of those last decision things to lose weight before school started. Excercising doesn't really seem to help for some reason, the only time I was around my goal weight (155-160) was 3 years ago when the coaches ran us until we puked and we conditioned like every other day or so, but now the coaches are slackers and don't really make us do anything but I think this year things will change for the better hopefully.
Posted by: KTA---------------------
losing weight can be done effectively without exercise and without "miracle" products. . . you just have to be conscious and smart about what you are eating . . . being healthy is not a three week diet torture, its the way you live.... . (although if you eat cake all day you would lose weight too. . but due to mal-nutrition rather than effective use of stored energy)
Quote:
Yeah, that's the problem. :silly:
Yea I decided not to buy it since y'all say I would dehydrate and all so I used my money to buy football gloves and gear and stuff.
Posted by: WaltCMoto---------------------
If it sounds to good to be true, it probely is. Dont be concerned with your weight, be concerned with your health and nutrition. Exercise on a regular basis, not just football season, eat healthy, and the results will happen. It takes a change in your eating habbits, and exercise routine.
Good luck, Walt
Posted by: lavidjio---------------------
lavidjio
Posted by: High Lord Gomer---------------------
How in the heck did this spambot find this topic to post on?!?
