PVC Fork seal driver HELP!
Posted by: MikeT---------------------
Guys, I've heard you can use a piece of PVC pipe as a fork seal driver. If I split the piece of PVC pipe, and put it around the lower fork tube, do I just slide the PVC pipe and hit the seal? Or, do I somehow hit the PVC pipe to drive the seal in? 1996 YZ125 forks
Thanks, my forks are apart and I await your response.
Posted by: kciH---------------------
I've used this before and I just used a long enough piece of PVC to get a good grip on it. Just slide the PVC down the fork tube repeatedly, with moderate force, and it will drive the seals home. Make sure to get the edge of the PVC you are using free of burrs and debris from when you cut it.
Posted by: KawieKX125---------------------
You can, just make sure to cut in in half! I got an adapter that had 6 inch pipe on one side and the proper diameter on the other so that i could use a mallot to hit the driver.
Kawie, can you discribe that a little more indepth? I am going to go to Home Depot and get some supplies tomorrow. How do the two tubes connect??
Posted by: ACS---------------------
I used the pvc pipe seal installer for nearly 12 years. Then I finally coughed up for a Motion Pro one. I was an idiot for those 12 years
The proper tool makes it so easy.
I've done it both ways, and I agree with ACS. If you've got the cash, I'd buy them. If you get a bike that has a different size fork than you currently have, you will easily get at least half what you paid for them back. I'd bet they would sell on this forum in 2 hours or less.
I know, but I don't have the bucks or the time to get one.
Posted by: Layton---------------------
I use the PVC but after I split it, I use a couple of hose clamps and tighten it on to the the fork tube. Then the mass of the fork tube acts as a sliding hammer. Pops the seal right in.
Quote:
Now we are talkin' I understand that.
