00'YZ426 fork oil level
Posted by: NO HAND---------------------
I would like to know what is the recommended oil level for a 00'YZ426. Thanks!
Posted by: BBD---------------------
90mm's would be max. You can use a lower oil level (120mm) and work your way up to 90 if need be. Put a ziptie around the fork leg under the dust seal so that you can see how much travel you are using. This way you can see the results of changing the clickers, soft or stiffer. If you clickers are around 6 or so out to keep from bottoming, then you might raise the oil level 5 or 10mm's and back off on the clickers. Same with too far out(14 or more). Then lower the level.
Very helpful! Thanks alot!
