Short Clutch Lever
Posted by: Dave S.---------------------
Does anybody have a recommendation for a shorter clutch lever to fit inside of "bark busters". I used to slide the clutch perch over, but I'd really like a shorter lever to give me more room on the bars. I bought a Moose lever but the bend does not seem to allow enough travel . Has anybody used an aftermarket clutch assembly? I ask this 'cause the threads for the lever bolt pulled out of the perch, so I probably need to replace the whole thing anyway. Any recommendations? Thanks for the help.
Posted by: ChuckyBoy---------------------
I just ordered an MSR Raptor "Shorty" clucth lever and perch. I expect delivery in the week or so. I'll let you know how it works out after I get it installed.
Chuck
Posted by: emde76---------------------
I use the Moose shorty (competition) levers, and the travel is fine. The Works Connection E-Z adjust universal billet clutch perch is pretty nice, but it requires the use of CR-style levers.
Posted by: MassKDX---------------------
I used the MSR clutch lever and it is muh shorter than the stock lever. I had to drill it out in order to use it in the stock perch.
