KDX 200 ratio
Posted by: kx125rida295---------------------
My friend has a 1984 kdx 200 and he is wondering what his ratio is 4 it. he thinks its about 40:1 but it cant b cuz its a older 2 stoke and they need more oil. i haev a 2001 2 stroke and mine is 32:1 so his should be aroun 28:1. I was just wondering what it is for his bike.
Thanks,
Kyle
Posted by: briora---------------------
well kyle, it should be between 32:1 and 40:1. thats what i was just told in an e-mail from a member of this site. Thanks man. ~1~
does anyone know the real answer? let me know, thanks. kx(blah blah) is my friend nd he thinks it'l be like 28:1 or sumthing. i think its about 40:1 and thats how i mix it.
Posted by: woodsy---------------------
What type of oil is he using?
Posted by: jmutiger---------------------
Where have all the smart people gone?
Wow..
Okay, here's some good info, from my Sponsor, Maxima..
http://www.maximausa.com/technical/oilmigration.html
Basically what it says that a small high revving engine has less contact time with the oil. A larger, slower revving engine has longer contact time with the oil, so you can use a bit less...
With that said, there is no advantage to putting in less oil, except that you save money on oil.. But a crank rebuild cost more than any oil I've ever bought.
Click around the Maxima site, they have some really good unbiased info.
Jon!
Posted by: dirtryder72---------------------
ill tell you what i would do i would find out what you really think the ratio is between take a safe number that is the richest in oil ratio mix a half gallon ride it out if it smoked to much use les oil repeat
Posted by: gooby---------------------
read this .jmutiger....where have all the smart people gone?....lol http://www.ericgorr.com/techarticles/carbtuning.html#m
Posted by: KTA---------------------
32:1 is usually a good mixture... but many mixtures should run through your bike just fine, provided the carb is jetted to match
Posted by: ASLCM---------------------
The OEM Book states 32:1 I perfer 40:1
