Chain Guide question
Posted by: Gomes-nz---------------------
I recently brought a 1991 KDX200 which has a 47T sprocket on the back. However I was told by the previous owner that the bottom slider of the chain guide was removed as it won't work with the large sprocket. However in my first Enduro, the chain came off, after being disloged by a larget stick. The chain was forced below and out of the chain guide and then off the rear sprocket.
Question: should the standard chain guide fit, it is now bent and I am considering an aftermarket replacement. Does someone make an aftermart one that will fit a 47T sprocket.
Any ideas ??
tks Darrin
1991 KDX200
1999 DR650
Posted by: BRush---------------------
The standard aftermarket replacement is the Fredette chain guide. Very strong. I don't know about a '91, but my '96 has a 50T rear and the Fredette guide works OK.
http://www.frpoffroad.com/Merchant2...tegory_Code=FRP
Posted by: Lew---------------------
I just replaced my broken stock chain guide with the fredette guide. Very strong! As for the 47 tooth sprocket, that is what came on my '01.
BRush - what fron cog do you have? I am running 12/47 to allow 108 link chain.
Lew
Posted by: Jim Crenca---------------------
My 1994 KDX has a 49 tooth sprocket & a Fredette chain guide.
There is a post on this forum regarding wear on the sides of the chain (my master link clip has to be replaced once or twice a year), but it is still the way to go IMO.
Lew
13/50 with a 110 link chain.
