Fork Switch Question
Posted by: ride_red_15---------------------
Is it possible to switch the forks off of an 02 CR250 to an 03 CRF450? Thanks in advance for the input,
Joe
Posted by: bclapham---------------------
i bet they fit, but i would expect the CRF would require stiffer valving and spring rates for the same rider so it would be a pointless operation if you are trying to take advantage of this situation.....but lets wait and see what the experts say!
Ive got a feeling the CRF forks are different length to the 250.
From what ive heard, on the 03 CRF the forks were extended to match those of the CR's
Posted by: ochster---------------------
I know the outer tubes on the 02' CRF are about 7-8mm longer than the CR.
Posted by: HONDA65---------------------
Not true on the upper tubes. They are the exact same part#. However, the lowers are different, and I would suspect that they are aliitle longer.
But if one were to order a set of Ohlins forks, they are the same fork for both the 250 and 450. I would hope that they were setup differently, but with my limited experience with Ohlins, I would suspect there are not.
Posted by: OldassKDX---------------------
I was under the impression that the forks were the same this year, but that the old CRF forks were a little shorter (10mm?)
Posted by: pro-design---------------------
Same forkf different spring rates and valving
Honda65, thanks for the correction. Turns out I measured them against a pre 00' CR fork, wich is indeed 8mm shoter than the 01' and later.
