Setting sag, hot or cold?
Posted by: clw---------------------
When is the correct time to adjust the sag, when the shock is cold or hot? I think tonight my static sag changed about 10mm after the shock got hot!
I had noticed that I thought there might be too much static sag when I unloaded the bike, but after riding, grabbed a bud to help with the measurements and found the back end sitting higher. Is this normal? The linkage is not binding.
Posted by: Esp1---------------------
Yes, it's totally normal. The sag measurement is always smaller/less when damper i hot, due to the preassure increase inside. Do your sag settings with cold damper. All specs on sag is cold. Good Luck!
