KDX80 Oil Leak
Posted by: mspyyz---------------------
My son's KDX80 (87) has an oil leak at the shifter rod exit. I am assuming this is likely an engine seal that needs to be changed. Do I need to take the lower end apart to do this or can it be done from the outside of the bike?
Posted by: grass-digger---------------------
i believe that most shifter seals are taken from the outside i know mine is and it was farely easy to change
Thanks for your reply, I will go to the dealer tonight and see if I can get one.
John
