output shaft oil seal
Posted by: brianhendry---------------------
started losing oil from theoutput shaft oil seal, do i have to split the cases to replace it. help please.
regards
brian
97 200kdx, fmfgnarly pipe, turbine core silencer, airbox mod,fatbars
Posted by: Canadian Dave---------------------
No you don't have to split the case not to worry.
Use the search function try entering "output". This topic has been covered many time on this forum and you should have no problem finding all the info you need to replace the seal.
David
