adding preload shims
Posted by: clw---------------------
WP43's-- do you put the spring shims on the top or bottom of the spring? Going to try a little more preload.
Posted by: Anssi---------------------
I strongly assume the top based on how the WP's with the external preload adjustment have the adjustment on top.
Also, all the forks I have seen have the shims on top (granted I've only seen the YZ250 KYBs and WP 45s and 48s).
Posted by: Jeremy Wilkey---------------------
CLW,
Top on WP's but Anssi on KYB bumper forks make sure you put them onb the bottom.
BR,
Jer
Thanks Jer and Annsi, I think I remembered reading somewhere that the YZ shims went on the bottom, the GG is different so thanks for the help. Again!
