Front axel spacer ? removing trip meter unit.
Posted by: Pretzel---------------------
Hello,
I`m going to remove the front wheel trip meter form the front axel and Id like to replace it with the correct size spacer.
When at the dealer I saw a 2002 Suzuki 250 that looked close.
Dose anyone know the part number that will work for a 2002 KDX 200
Cheers !
P-
Posted by: RTL---------------------
I did not replace with a spacer, but instead used a Ty Davis cable plug which fills the hole perfectly. I switch between enduro and mx setup in minutes. Just my 02.
Posted by: rv6junkie---------------------
You might want to remove the bevel gear inside the hub.
Posted by: TransAm77---------------------
I just put a cap on mine too. I used the protective cover off of an R/C car glow plug. Fit perfectly.
Posted by: kx_693---------------------
i just filled mine with some silicone, i race it every weekend and i havent hand a problem with it yet
Posted by: KDX'r in IN---------------------
I filled mine with super blue wheel bearing grease(automotive). Works pretty good. Through two years of riding and who knows how many pressure washings I have added grease one time. Plus I think I can just put the cable back in and go.
Posted by: gooby---------------------
I've been meaning to check with Stroker 4 stroke speed equip ,they make a spacer to get rid of the odo drive on the klx.Since the odo is the same on the klx ,kdx....i believe ,that might work.I'll call them monday
Posted by: Lew---------------------
http://www.strokerspeedequipment.com/ $19.99
Just left buykawi and all individual part numbers for the front hub and odometer assy. are the same between the 01 klx 300 and 01 kdx 220
Lew
Talked to stroker,they said yes they work on the kdx too.
Posted by: Braahp---------------------
Go down to your local hardware store and get a rubber cap/plug and fill the hole for less than a dollar. The screw will hold it right in there.
Thanks gooby and Lew this is exactly what I was looking for !!
P-
Posted by: rcers---------------------
I made a replacement spacer for my sons KDX out of aluminu.If you have access to machine shop I will send you a sketch of the part I made,works great.
rcers538@cs.com
Hello,
For the record I bought a fork Spacer from Strokers an it worked out just fine.
Thank guys !
