2001 Gas Gas XC 300
Posted by: justql---------------------
2001 XC 300 Gas Gas
LTR Jetting Kit, Chain Guide, Power Valve Cover and Case Saver.
CRD Polished Aluminum Skid Plate and Frame Gaurd.
Eline Accessories Carbon Fiber Pipe Gaurd and Front Rotor Gaurd.
Protaper Bars with handgaurds with Knights mounting hardware.
FMF Pipe, Boyenson Valve.
This bike has a small dent on the pipe (up high on the top of the pipe) The pipe gaurd is also cracked in a circle shape about the size if a quarter in the same place.
There is a hole about a quarter inch in diameter in the seat cover.
The clear coat has pealed off of the rear fender and the decals on the rear fender are rubbed a little bit.
It needs new fork seals, fork caps and the carb needs to be tweeked. It will come with a new float assembly,choke assembly,fork caps and fork seals. This stuff will not be installed.
$3400 or best offer. I need to sell this thing. It's too nice a bike to just sit around. I just do not have the time to ride it between work, school, family and hunting for a new job.
Posted by: Stan_Flemmings---------------------
Say it ain't so
This is a nice bike, guys. His loss, you're gain.
Posted by: Calcaneus---------------------
New job? Sorry to here that Justin. I wish you good luck.
bump
Posted by: KTM250RDR---------------------
Do you have any pictures? E-mail me at ktm250rdr@aol.com. Where are you located?
Chris
Southern Kansas. I have some pics some where. I'll try to find them as well as taking some new ones.
The bike also has an mx front number plate as well as the headlight, and LTR dogbones. I also have an Pacemaker computer and aluminum mount and damper that I might be willing to sell as well(with the bike only).
