Setting the sag...
Posted by: KDXFreestyle---------------------
Hi, i know what the sag is and stuff, and how to measure it. But how do you adjust it? Do oyu just adjust it with the "clicks"? Or on the shock? if on the shock, how do you do it?
THANX
Posted by: fatty_k---------------------
You use the 2 collars that hold the shock spring, to adjust the spring preload, adjusting ride height. Loosen the top lock collar with a punch and a hammer, then turn the other collar to tigten/loosen the collar to put more or less preload on the sping. You can use either a blunt punch or a screw driver, or you can buy "special" punches from Race Tech to make the job easier.
ok thanx....... I'm all set now
