Q about setting sag
Posted by: Slash---------------------
Hi!
If the sag with me on is the correct 100mm (Racesag?), but the sag without me (has a name?) is 40mm, is that an indication to change to softer spring?
Posted by: Fred T---------------------
That's "STATIC" sag and it should be around an inch. (25MM to 35MM) So you're on the boarder of needing a lighter spring, however if you checked the sag with out gear, tool belt and a drink system on then you'll be ok.
Thanx Fred! I just have a few more beers after each ride and it will be ok... :-)
I also see that u have the bike (KTM 250 EXC) that i think is my next one too. However i will spend some more time on my -90 KDX to learn tech and riding before i move to the orange team. If u want to compare the bikes for me it would be nice!
I did. Here's the link to the comparison. Seems like a long time ago now that I'm so used to the bike. Still loving it.
http://www.dirtrider.net/forums3/sh...&threadid=58559
