Originally posted by Danman Remember as you approach the minimum and maximum of you wrenches range it becomes less accurate. Its most accurate if you stay in the middle of the range. |
Originally posted by Patman You should have looked up Thump, he swears his "by feel" method works fine. Then again he's also the one that had YZF guts poking out the cases
