Good harescramble or trails bike
Posted by: kstarr87---------------------
Hi i have a 2002 rm85 and am goin to get a new bike soon. I mostly ride trails and do hare scrambles. I do motox every once and a while. I am 15 years old and am 5'1" amd weigh 125 pounds.
Thanks Kevin
Posted by: beer_stud_76---------------------
kevin -
now you're on the right track. if you're ready to move frum an RM85 i'm guessing that you are pretty fast, confident, and competent. this is a good thing. a fast, confident guy at 5'1" has a lot more options available than a begginer.
basically, for you, this issue is fit. you can probably handle any amount of power, but getting it in a package that fits is tricky. as i mentioned in response to your other post, there are several things that can be done to shorten a bike - suspension, seat foam, (i guess thats about it...).
my advice is to check out as many bikes as possible and find a few that fit or come close. talk to some mechanics and ask about fitting a bike to you. and decide how firmly planted you must be to feel safe. if you can safely tippy toe, a lot more options will open for you.
here are some bikes to look at (this is not an exhaustive list): KDX's, KTM 125 or 200 EXC/MXC, YZF/WR250. . .in stock form i'm certian that these bikes will be too tall but they can all be lowered and you can change bars and triple clamp for a more compact cockpit.
hope this helps.
jeremiah
Posted by: Red Rider 53---------------------
If you can wait for a few months the CRF250 will be out. That will probaly be a little too tall in stock form too. There will be two different models of the CRF250, the "R" model (motox) and the "X" model (off-road). However they will both have the same engine.
Hey, by the way, maybe you can help me out. You said you had a RM85 and did mostly trails and harescrambles. I am getting a CR80 pretty soon, but I want to do trails with it and don't know if that would be the right bike. Any advice you can give me about that would be great!
I have an FMF fatty and power core 2 shorty silencer on it. I think it does pretty well in the trails. You will probually wanna get bark busters. I think the cr80 will be fine too. I think the suspension is good for trails too because it has a pretty smooth ride and i ride on tight trails with rocks and vines and suff like that all over.
What's a bark buster? And would a FMFQ work with the fatty?
Posted by: Patman---------------------
kstarr look hard at the KTM200 it might be just perfect for what you want. The KDX wouldn't be bad but I think it's will need more work if you are aggressive and/or MX.
RR53 why not look at the CRF150 for a killer trail rig with gobs of potential?
Which ktm 200 the exc mxc or the sx?
Quote:
A bark buster is a guard that attaches to your handlebars and it protecks ur levers and hands.
If your into tight, snotty, nasty east coast trails with a little MX then the EXC is a great choice if you ride more two track open type stuff and more MX then the MXC would be better. Basically it's wide ratio trans. or close ratio trans.
I ride in some single track stuff but i mostly like to ride double track. So u think the mxc would be good? What about the kdx 200 is that a good trails bike? I found a lowering kit for that because im only 5'1".
The KDX is a great trail bike but that's it's job, asking it to be a MX'er is pushing it's comfort zone a lot. If your going to go to the MX track and be serious you'll want the KTM or a modd'ed KDX. If you Want a close ratio transmission like you would use on a track or pretty open HS type riding them the MXC is a good choice. If on the other hand you want to do it all then the EXC is going to be VERY hard to beat as a do it all bike. Suspension lowering is a specialized thing, even more so than suspension modification to existing travel so pick your tuner carefully. MX-Tech has a long history of making bikes really work for those that are short of inseam like Mr. Rich Rohrich that you'll see around here. As a matter of fact he appears in Eric Gorr's new book as an example of what can be done.
Thanks patman for all your help!!!
Posted by: burn_one6---------------------
well i race only hair scrambles and alot of woods ridding the two bikes i have owned that where the best for this are a husqvarna 250 and an american made ATK 250 the ATK125 is a great woods bike perfect for hair scrambles
