Search issues
I have ISSUES!!!
I put in, 'kx kdx fork swap', and get the following complaint dialog:
'The search term you specified (kx) is under the minimum word length (3) and therefore will not be found. Please make this term longer.'
If I put 'AND' between all of the words, I get the same complaint.
Howcome?
Posted by: D36-108A---------------------
No single word/term/item may be under three characters. This is a real problem when you want to search on, say, 97 CR250. I suggest you try KX125 or KX250 instead of KX.
I'm wondering if, due to DRN's search limitation, it might be better to Google it, limiting Google to DRN.
Well...that is rather self explanatory, 'eh?
I made it complicated..thinking, 'There ARE at least three words!!'
I'm famous for saying, 'Words mean things!'. Maybe I should read some myself sometime!
Thanks for stating the obvious to the obviously impaired. And you were even nice about it!!
Thank you.
Posted by: Patman---------------------
BRAVO for at least trying to use the search feature! Most just create a new thread and let somebody else search it for them. You get a gold star today. :thumb:
Posted by: Green Horn---------------------
Quote:
Yeah, and it's so much easier that way...
Well...that's what happened. It was I using the search function in response to a post of, 'I can't find it!!'
.....I didn't find it to be 'easier' at all.
.....not even with words more'n three letters long!
Oh well.
