Wider Foot Pegs
Posted by: PimpSLAYER---------------------
I would like to know where I can find some wider foot pegs for my 1993 CR250R. I thought that I saw a place that had extensions that you could weld on but I can not remember where I saw'em... Fastway makes a nice pair but, they only fit 1995 and above, are some foot pegs interchangable, thanks guys!
Posted by: nick414---------------------
How about getting a pair of junkyard pegs, cutting them in half and welding them on your existing pegs? That's what my bro used to do. Cheaper, and you can make them just the way you want 'em!
Posted by: MXP1MP---------------------
You should be able to put pegs from a 95 on a 93 I don't recall honda changing the actual peg mounts on the frame from like 92 thru 96 just the size of the pegs. You should be able to make them fit with minimal modification if needed. The only change I remember honda doing was just making the actual peg width just wider.
Thankyou guys for the insight!
vBulletin Copyright ©2000 - 2010, Jelsoft Enterprises Limited.
vB Easy Archive Final ©2000 - 2010 - Created by Stefan "Xenon" Kaeser
