Pro Clean ?
Posted by: JWW---------------------
I used Pro Clean for the first time last weekend. It has left a residue all over the bike. Since the bike was heavily soiled I mixed it to the strongest ratio on back. I eye balled the measurement instead of using a actual measuring device.
Could this residue be from to much concentrate and do I need to get the residue off right away?
Jeff
possible ex-simple green user
Posted by: alphado---------------------
Did you rinse it off? I have used it for over a year now without any residue, I mixed it 50/50 with water. I love it!
Posted by: Zenith---------------------
I'd say you just didn't rinse it enough. I've been using it for a few years now and have noticed if you don't rinse for long enough it leaves a residue. I use it neat from the bottle, just spray it on. Are you watering it down to put in your power washers or what?
Posted by: Thump---------------------
You're only supposed to let it sit on the bike for 15-20 seconds then rinse clean. Don't know if you let it sit too long or nor rinse enough. I too have been using it for abut a year and love the stuff.
I flooded the bike as the instructions said to do. Now that I think about it I did let it sit on longer than 20 seconds. I started playing with the dog while I was cleaning.
I will give it another try this weekend and post my results.
I'd give it closer to a minute, especially if you are diluting it. Although that's here where you practically need to use nuclear weapons to get the muck stains off. You'll know if you washed it off too soon or diluted it too much as soon as you rinse it off anyway...
We can't get Simple Green over here but I always hear you guys saying how great it is, how does it compare to Pro Clean out of interest?
And one last thing, is your Pro Clean yellow or clear? It is usually yellow here but one time it came clear but the clear stuff didn't seem to be nearly as good...
