Piston port modification
Given an mx-tech revalve on a set of 43mm kyb forks...does that include piston port modification? Meaning grinding, enlarging...actual orifice reshape?
Not looking for any secrets. I am looking to do such modification and am looking for as much advance info I can get before they're actually taken apart.
Forewarned is forearmed or somesuch.....
Tanks!
On a full mx tech setup jer installs the low flow pistons.Im guessing yours have been revalved using std pistons and i would be surprised if jer modifies these as they are good pistons, if you are looking for a med flow.Its best to give jer a call as he doesnt have as much time as before.Only he will be able to tell you exactly the info you need.
