Yamaha Rinaldi Parts
Posted by: yamayz125---------------------
Have anyone tried/heard about Yamaha Rinaldi parts?
Is the Exhaust pipe w/silencer good?
(most interested to hear about 125cc-parts)
http://www.yamaha-racingparts.com/yrrd/index.html
Cylinder Head Sand-casted type with different combustion chamber for improved cooling and performance.
Cylinder + exhaust valve Modified production cylinder, based upon YZ125 2003 model.
Piston Piston for new 2002 and 2003 YZ125 cylinder. Note; standard YZ piston cannot be used with YRRD kit cylinder and head.
Reed valve Carbon fiber for better response and durability. Biaxial type.
CDI YRRD latest generation CDI box providing optimum ignition characteristics.
Exhaust pipe Special pipe that is different from 2002 spec. The kit comes with two different exhaust pipe specifications: version "T" for Top power and version "L" for Low rpm/bottom power.
Silencer Special type made of new material (different from 2002 model, presently under testing).
Magneto rotor unit Magneto rotor with higher inertia than standard YZ125.
Valve breather, 1 Aluminium plug for valve breather 1 hose.
Crankcase Cover Machined factory crankcase cover for higher rigidity.
Carburetor setting parts Kit includes all parts for optimum setting of Mikuni YZ125 '03.
Kit manual Instructions for correct installment of the YRRD kit.
Optional
Clutch Hinson machined clutch for higher durability and smoother operation (available as full set only).
