Rocky Mountain lists a front brake line for a CR250 that spans years 1995 - 2003. Am I to assume this line will mate with the Master cyl and caliper on my YZ250? I'm pretty sure it would but I just want to hear it from someone else.
I'll order the Fastline brake line from Rocky but still not so sure about the $20 clamp. |
Originally posted by SFO The fastline frt line I recieved for my yz was not indexed correctly between the swaged fittings and the sheath was loose on the outside so you couldn't affix it properly to the fork gaurd. I used to make custom brake lines for m/c's and wouldn't have sold a product as ill refined as the fastline. I would not buy another or suggest that anyone purchase one. I have had better luck with the galpher line but having a line with indexable fittings is the dope set up, and you could trim the length if your bars are cut down. |
Originally posted by muscle I dont understand what you mean by indexed correctly. Are you saying that you can interchange the type of fittings on the brakeline? Why would you want to? |
:thumb:
Many riders will be interested in this. Cant wait to get my new brake line!
