Originally posted by Smit-Dog 2) The stock bars have these little steel washers spot welded into the ends of the bars. You have to drill them out to secure the BB ends. Or you could take a pipe cutter and cut off about .5-1" on either end of the bars. This gets rid of the washers, and makes the bars narrower for tight woods riding. |
Originally posted by Tantrum ... If you are a tree smacker, consider the hard plastic ones without the alum reinforcing bar. If you whack alot of things, something has to give, and its usually the mount on the inside of the grips for the barkbusters that have the alum. reinforcing bar in them. Plastic ones seem to absorb the shock a little better, but put your hands at greater risk. 6 to one and half a dozen to the other. |
Originally posted by Smit-Dog Call me crazy, but there is no way I would suggest hard plastic "hand guards" over aluminum bark busters if you are smacking trees. The plastic-only guards only protect you from mud, roost, and very small branches. If you smack a tree with one of these, you'll have plenty of time to shop around for a decent set of aluminum BB while your broken fingers heal in a cast. |
Originally posted by Jackpiner57 I use Enduro Engineering busters, but I have a complaint. The plastic deflectors are mounted on the inside. I went down and it ripped the deflector right off one of the little screws that hold it on. I'll have to take the screw out and put a little washer on it. |
