Originally posted by woodsy Not sure about the 125's of that era but the 250's had tranny issues and clutch problems. Start it and pull the clutch in, drop it in 1st - does the bike want to creep forward? If it does the clutch basket is shot (the baskets on the 250's were VERY soft and like to develop "saw teeth". Ride it thru the gears and make sure it shifts without feeling overly tight int the trans! Woodsy |
Originally posted by a454elk Here you go: 10th digit is the one to look at B=1981 C=1982 D=1983 E=1984 F=1985 G=1986 H=1987 J=1988 K=1989 L=1990 M=1991 N=1992 P=1993 R=1994 S=1995 T=1996 V=1997 W=1998 X=1999 Y=2000 1=2001 2=2002 3=2003 4=2004 As long as it's a conforming Vin through the US and Canada (usually) this will work. If it's not intended for import into the US, they don't use the same standards.
