Fs: '99 Cr250
Posted by: CRPilot---------------------
New bike just arrived so this one has to go.
Includes:
Race tech gold valves set for 190lb intermediate mx
.44/5.1 springs (unused stock spings included also)
Shock body has been hard coated black for longer wear (race tech)
Shock shaft is a TiN coated high flow works shaft (48 clicks of adj)
Two rides on fresh fork rebuild(Oil, seals and all bushings)
Fresh shock oil done at the same time
Zero rides on new plastic and graphics (Except number plate)
Works connection skid plate
Carbon tech reeds (extra boyesen spares)
Pro-circut foot pegs
Pro-Circut Pipe and silencer (works not platinum)
Stock pipe and silencer never used (not even once)
New front brake pads (two rides)
Eric Gorr Mo better porting :thumb:
High seat foam and new gripper seat cover
Stock foam and seat cover included
Twin Air Filter
DID x ring chain
New crank installed Spring of 02 (preventative maintenance not from seizure)
Its ready for a new piston which is included as well as a new cometic gasket kit (you can install it so you know its done to your liking) Tranny oil and air filter have been changed every ride.
Other extras available for $$
I should have some pictures available in a few days.
If interested e-mail at jmbeckman@yahoo.com or call 414-899-2276
$2800
Located in Southeast WI
A few pictures can be seen at the following URL:
http://photos.yahoo.com/bc/jmbeckma...otos.yahoo.com/
ttt
