clutch plates
Posted by: marcelou---------------------
I have a kdx 200 , 1994 and i think that the clutch plates are broken or burned... because when the bike opens the valves inmediately i have to put the next shift because the clutch start to slide... here in Argentina there are available de kawasaki oem clutch plates and answer m3 proseries clutch plates, can somebody tell me if the answer clutch plates works properlly, because this are cheapier than the kawasaki oem clutch plates..
Posted by: jaguar---------------------
I'd go with the Answer plates. But it could be that the clutch springs need replacing too. If they are shorter than 34.5mm then they are too weak.
I can't say one way or another about 3rd party plates...BUT... do consider the XR plates that fit the kawi. They fit the basket fine, but the surface area is considerably larger.
I believe it's the 86-99 xr250r plates for the 'H' model. Better check on that for a '94.
That's not much help, 'eh?
Actually, it's no help whatsoever!!
Ah well.............
