99 KX250 forks
Posted by: MikeKX250---------------------
I want to make my forks more plush for the woods. I have a friend who has a 01 KX250 with revavled forks that work very well in the woods. If I copy his set-up will it work right in my 99 forks?
This is his set-up,
Midvalve converted to check valve.
midvalve-
Comp side( check valve)
25-.012 washer
25-.004
Piston
Reb side
23-.004 All .004
23
13
20
17
14
11
11
Base Valve
Comp side
24-.004
24-.004
20-.004
16-.004
12-.004
23-.004
20-.004
18-.004
16-.004
14-.006
11-.010
13-.004
15-.004
17-.020 washer
17-.020 washer
Reb side
25-.016 check plate
How much would it cost me to buy these parts, and where can I get them?
Posted by: dbrace---------------------
I dont understand your shim thickness? These two forks are quite different but as your friends bike has a bladder fork and yours does not.
I just read that compression stack again and find it interesting (wierd) but if you like it thats all that counts.
He is very happy with that set-up.
Posted by: MSracer---------------------
He is putting the thickness in inches instead on mm.
I think both of those forks use the 28mm cartridge so your results might be close to what your friend has.
Looks to me like a few of those shims on the base may be there just to add height so the nut doesn`t run out of threads.
Posted by: NEMX305---------------------
Quote:
Bladders and rb are removed from his friends forks. And his knucklehead friend did take those shim thickness measurements in inches. Tim
Where can I buy the shims?
mxtech
