Argon to charge rear shock?
Posted by: KXaggerator---------------------
I was wondering if I can use the argon for my TIG to charge my rear shock since it is an inert gas?
Posted by: bclapham---------------------
i think so, argon is more inert than Nitrogen and also slightly denser. i will probably use argon when i do mine since we have more argon tanks at work than nitrogen. if its from cylinder it will be sqeaky clean also.
Posted by: Brewster---------------------
Do you have a 200 lb. pressure regulator for the argon tank?
Ride on
Brewster
the regulators for argon and N2 cylinders are interchangable
