Fork Preload
Posted by: TNUTT---------------------
HOW DO YOU SET THRE FORK PRE-LOAD?
Posted by: mxneagle---------------------
Usually with spacers on the the top between the spring and the fork cap. I haven't messed with it on showa twin chambers though. On those probably spacers on the outside of the cartridge where the spring flange stops.
Posted by: jaguar---------------------
with you sitting on the bike very balanced with little foot pressure on the ground your forks should move 3-4 inches from fully extended. If they move 5 inches then add 1 inch spacers to preload them more.
