Got my Gold valves
Posted by: pyromaniac---------------------
I got and installed my race tech gold valves today but it didnt contain any 11mm shims which is used in almost any settings. So i just ran without it. The forks are much softer now as i wanted. I just have to wait to go to the track and see how it works and hopefully doesnt bottom. So far so good.
Its real nice on my twin chamber forks, i only have to unbolt the handlebar and screw/pull out the cap on the top of the fork to get the valving out to change the shims.
Posted by: TNUTT---------------------
I don't know if your bike has the mid-valve, but if you dom did you remove it or leave it in?
Yeah it have midvalve and i removed it.
Posted by: kevin5758---------------------
You might be loosing alittle oil each time you remove the forks compression assembly. (leaving it on the bike) This would effect your oil ht.
That would be very little and its just to add a cap of oil. My setting without the 11mm shims is something between cH1 and cH2. Its pretty soft but it could be even softer. The spring shouldnt do much to the stiffness of the bike but i have 4.2 and spring generator recommends me 3.8. How much sag should i have in the forks? I think its about 6-7cm race sag now.
Posted by: Robcolo---------------------
The spring has a WHOLE lot to do with the stiffness. I went from a .365 to a .38 and it's a totally different bike [way too stiff] A .42 is much stiffer than a .38. Race Tech has figured the rebound numbers on the .38 spring they recommended, so if you hav in there the .42, the rebound will be way too soft.
