Pro Circuit Platinum II
Posted by: Ryan_KDX_---------------------
Has anyone tried this pipe? How does it compare with the FMF Gnarly?
Posted by: jaguar---------------------
I have a regular platinum pipe (less wall thickness than the II) on my KDX and it helped out the most on top end power and being able to rev out.
I don't know how it compares to the FMF gnarly.
That the only difference between the two?? I thought the II was a whole new pipe.
I remember reading that its just thicker. Thats all it needed since its a great pipe but mine has a couple dings in it which may not of happened if I had the II version.
Posted by: Racer#213---------------------
i'm 98% sure they're separate pipes, teh platinum is more for top-end gains, where the platinum 2 is set up for bottom end, ie to compete with gnarly.
I think now is the time to get the story straight.
ProCircuit
e-mail: info@procircuit.com
phone: 909-738-8050
Posted by: b-b00gie---------------------
Quote:
Nope, the Platinum 2 is a different pipe than the Works/Platinum. The Works/Platinum is a top end pipe, while the new Platinum 2 is a bottom end pipe...
"Pro Circuit's latest model, the Platinum 2, is an extremely technical pipe that utilizes state of the art heavy-duty construction that challenges the limits of all terrains. The innovative system helps with increased bottom to mid-range power, making it perfect for unique styles of riding. The entire body is contructed from 18 gauge metal to help with added protection against rock damage and the rigors of offroad racing. The Platinum 2 also has a nickel-plating finish and corrosion solution for prolonged life. Designed as a high performance torge pipe that generates excellent traction and maintains a comfortable roll-on power, the Platinum 2 is the ideal pipe for riding in tight conditions or for anyone looking for more snap."
Also, unless theres been changes since their catalog was printed, its only available for the following bikes...
CR 250
YZ 250
KX 250
KDX 200/220
RM 250
250 SX
300 MXC
250/250R/300 EXC
