Question about KX Forks
Posted by: Hick---------------------
Not sure if this should be in the CR/KX/RM/YZ forum or in Suspension forum.....
Anyway, my question is what are the differences between '02 KX 125 and 250 forks? Overall length and travel? Caliper mounts? Spring rates? Valving?
Thanks in advance for any and all replies.
Im not 100% positive on this but i think the only difference is the base valving and fork springs are stiffer on the 250(i dont think they even alter the rebound-just run the clickers in a few more clicks on the 250).I would be very surprised to find any other differences.
Posted by: Jeff Howe---------------------
The base valving is the same, midvalve is the same, rebound valving is the same and only difference is the spring rate.
Right on.
Thank you very much Marcus and Shocknut. I appreciate it.
