2003 cr250 initial settings
Posted by: pro2k---------------------
What do you guys recommend for a beginning rider on the track as far as set up for compression/rebound on a 2003 cr250. I weigh about 160lbs w/o gear. Thanks for the input!
Posted by: rideright---------------------
You probably need a good revalve, but for starters just to get you in the ballpark, you need to go to a .41 to .42 fork spring and a 4.8 rear spring. Stock is .44 and 5.1.
Set oil height to 365cc
After that if you still want to try it without a revalve, set the forks to reb. 12 out, comp to 16 out and bleed the air a lot. Set shock to 2 turns on the high speed comp and 18 on low speed comp and then set the rebound to 12 out.
Posted by: yzrider_69---------------------
owners manual should have something on the shock adjuster and compression damping adjuster you can try to adjust your suspension by if u dont feel like getting into anything.
