XT 600 misfire
Posted by: GreenPeace---------------------
I own a XT600 Tenere. The bike start and idle without any problem.
Around 3000 rpm the bike misfire & doesnt pick up more revs.
I changed the carb, ignition coil, CDI and still does the same.
The pick up and ignition coil measures correctly according to manual.
The problem started after I replaced the piston.
I set the cam timing correctly when assembling the top end but now I have my doubts.
Will that be the symptom if the cam timing is out?
Posted by: BunduBasher---------------------
I don't think the American know what a Tenere is, we are hard done by and deprived of European spec bikes here in the good old USofEh.
Posted by: ugd420---------------------
What kind of piston did you install?(stock,oversize,high comp.)
Posted by: SpeedyManiac---------------------
How is the spark plug? First thing I would check is jetting, then timing.
