| Where am I going with this? Well, if you are picky about air psi then you must be aware that if you fill with wet air, which 99.999% of folks do, then you will definately change pressures on a consistant basis with a simple outside temp change. You MUST have dry air (or nitrogen for that matter) to accomplish a fill that will remain consistant |
