Ice screw Rules
Posted by: JeffWudi---------------------
Does anyone know if the design of ice racing screws is regulated any where? Height of the head, or diameter. Which organization would know?
Jeff
Posted by: kbud---------------------
The AMA regulates ice screws. Search their site.
I found something. http://www.ama-cycle.org/rulebooks/ It's a PDF so you will need adobe acrobat. Section Q talks about ice racing.
1. All solo and sidecar machines will use studded tires, except rubber solo and sidecar classes. The studs will be an unaltered #7 to #10 hex headed screw with no more than one slot, uncut, no drilling or hollowing out of the head and the screw to be flush into the tire tightly, not using a shim or washer to hold it out from the tire. The screw head cannot exceed 3/16” above the tire. There will be no cut tires.
2. Sidecar only – studded sidecar classes will be allowed to run with fully studded tires.
3. Solo class – No screws on the right outside knob of the front and rear tire.
This is from District 14 AMA rules.
Posted by: Patman---------------------
Always be on top or you might get frost bite on your.... oh wait never mind.
