Originally Posted by WrenchDaddy
I have done a few things to my nephew's PW80 to help the performance. Most are inexpensive and you can do them yourself.
1) Remove the rubber snorkel on the airbox, this allows it to rev much better. 2) Raise the clip on the needle in the carburetor on notch. 3) Remove the exhaust silencer and cut off the restrictive cone piece on the end of it. 4) Redrill a new rear shock mounting hole 1" further back on the frame, this will raise the back of the bike up and improve handling. 5) Raise the fork oil height to 6.5" from the top of the tube. Make sure the forks are compressed and springs are removed when doing this. 6) Add a 1/2" preload spacer to the top of the fork spring. (PVC tubing works well). 7) Remove some of the steel balls in the centrifugal clutch to raise the engagement rpm. (Leave an open space in between each one and distribute them evenly). 8) Change the gearing (We are in the process of finding the right setup). |
Originally Posted by gwcrim
Just out of curiosity, what did all that cost?
Originally Posted by bennjito
the snorkel is the thig that connects the carb to the airbox
i got my filter off ****, its just a standard 1 inch k&n fitted straight onto the carb, the lifter kit is also a great addition. i think it looks better, can someone tell me how to post a picture so you guys can see.
Originally Posted by FruDaddy
Pull the carb, then the manifold, and then the reed block, if I remember correctly. It is really simple, but a little easier with the tank removed as well.
Originally Posted by xploder182
hey
im a newbie thinking of buying a jianshe coyote 80 (the same as the pw80 but at half the price) do you guys know whether it will be anywhere near as durable or have as good performance when modded as the Pw 80? |
The oldest 80 is a 1983 which is standard except for a tal pipe.The 2nd 80 is 1991 and the one we are going to mod/tune.The 50(1981 model) we can not part with it's one of the family we have had it that long.
