I-cat
Posted by: booksie---------------------
Anybody ever used one of these.too good to be for real
Gain Over 5bhp In Under 2 Seconds
Graph shows power (bhp) against time (seconds). A standard YZ 250 2002 was used to record a base line (blue). The same machine was fitted with an i-Cat unit and retested (orange). The improvement in throttle response at 1.87 seconds is a massive 5.4bhp !
The i-Cat uses its Superior Burn Technology (SBT) to extract maximum performance from your engine.
The i-Cats SBT enables the air/fuel mixture to be burnt substantially quicker and more effectively, leaving the chamber with a perfect environment for continuous optimum combustion.
The fact that better combustion takes place means that all the available energy generated is transferred into performance whilst improving fuel combustion and reducing emissions.
The i-Cat is race proven and is currently being used by Albion KTM UK Grand Prix Team. It is especially sucessful with 2-STROKE and 4-STROKE MX engines.
This significant change to the ignition system results in:
Improved throttle response.
Better bottom end power.
Controllable power delivery.
Easier starting.
Engine pulls throughout the rev range.
Reduced engine bog down.
Improved race starts
