What rider weight is the CRF450 setup for stock?
Posted by: jsmith811---------------------
Just curious what rider weight the 450 is setup for stock. I have always been a little heavy for the stock yzf 250 suspension.. I may move up to a 450 this year.
Posted by: cr lover---------------------
i did some research at race tech and they say its set up for a 220lb rider but my owners manual say 150 to 160. i have a 04 crf and i weigh 217lbs no gear and i run my clickers at the softest setting. so i think race tech i right.
Posted by: Thump---------------------
:scream: I am 205 w/o gear and my 03 was WAY soft in the middle. Too easy to bottom out and if I turned the compression up it would get too harsh at the top of the stroke and I would still bottom it out. It lacked mid-valve resistance.
IMO both the manual and RT are right. The Top of the stroke is set for a 220lb rider but the middle and bottom 1/3 are week probably perfct for a 160-180lb rider.
I had my suspension on the 04 done by MX-Tech to curb the problem this year.
vBulletin Copyright ©2000 - 2013, Jelsoft Enterprises Limited.
vB Easy Archive Final ©2000 - 2013 - Created by Stefan "Xenon" Kaeser
